K65 Allowing for Cache and DMA coherence
842件の閲覧回数
unknowncoder
Background
  • I am looking at enabling the code cache controller on the K65 to improve performance.
  • I utilize DMA for peripheral to memory and memory to peripheral transfer.
  • I know cache and DMA don't normally work good together and the normal operation is to invalidate the cache before/after, read/write respectively.
Question
  • From the Table 30-1 it shows that SRAM is non-cacheable. Given this if I make sure that all access with DMA occurs within SRAM would I need to invalidate the cache still?
タグ(4)
3 返答(返信)
770件の閲覧回数
jingpan
Yes, you are right. SRAM in K65 is a kind of TCM. Its speed is same as M4 kernel. It needn't cache.
Jing
770件の閲覧回数
unknowncoder
Are both upper and lower memory tightly coupled memory to the core?
770件の閲覧回数
jingpan
Yes.
Jing
