Hello all,
I am working on an application in Codewarrior for the K64F that requires a variable frequency PWM output on 6 different pins. I attempted first to use the PWM bean, but it doesnt have any obvious way to change the frequency in run-time. This led me to the PPG component, but it doesnt share its frequency to other PPG outputs. My goal is to share a common configurable frequency across the outputs on a certain clock output. as an example, the test I'm using is FTM0_C0V and FTM0_C1V. I am attempting to have both of them share a frequency of 17.4768 ms, with a different duty cycle on each output. Is there a configuration setting I'm missing, or a different way to solve this issue? Any help would be appreciated.
-Thanks
Nate Hinshaw
已解决! 转到解答。
I just tried the following code and measured 6 PWM outputs on the FRDM-K64F.
PWM_INTERRUPT_SETUP pwm_setup;
pwm_setup.int_type = PWM_INTERRUPT;
pwm_setup.pwm_mode = (PWM_SYS_CLK | PWM_PRESCALER_128 | PWM_EDGE_ALIGNED); // clock PWM timer from the system clock with /128 pre-scaler
pwm_setup.int_handler = 0; // no user interrupt call-back on PWM cycle
pwm_setup.pwm_reference = (_TIMER_0 | 3); // timer module 0, channel 3
pwm_setup.pwm_frequency = PWM_FREQUENCY(54, 128); // generate 54Hz on PWM output
pwm_setup.pwm_value = _PWM_PERCENT(20, pwm_setup.pwm_frequency); // 20% PWM (high/low)
fnConfigureInterrupt((void *)&pwm_setup); // enter configuration for PWM test
pwm_setup.pwm_reference = (_TIMER_0 | 2); // timer module 0, channel 2
pwm_setup.pwm_mode |= PWM_POLARITY; // change polarity of following channels
pwm_setup.pwm_value = _PWM_TENTH_PERCENT(706, pwm_setup.pwm_frequency); // 70.6% PWM (low/high)
pwm_setup.pwm_value = _PWM_TENTH_PERCENT(553, pwm_setup.pwm_frequency); // 55.3% PWM (low/high)
pwm_setup.pwm_reference = (_TIMER_0 | 1);
pwm_setup.pwm_value = _PWM_TENTH_PERCENT(249, pwm_setup.pwm_frequency); // 24.9% PWM (low/high)
pwm_setup.pwm_reference = (_TIMER_0 | 0);
pwm_setup.pwm_value = _PWM_TENTH_PERCENT(129, pwm_setup.pwm_frequency); // 12.9% PWM (low/high)
pwm_setup.pwm_reference = (_TIMER_0 | 4);
pwm_setup.pwm_value = _PWM_TENTH_PERCENT(20, pwm_setup.pwm_frequency); // 2.0% PWM (low/high)
pwm_setup.pwm_reference = (_TIMER_0 | 5);
54Hz output frequency on all
FlexTimer 0 - channel 3 = 20% high PTC4 = J2-4
FlexTimer 0 - channel 2 = 70.6% low PTC3 = J1-16
FlexTimer 0 - channel 1 = 55.3% low PTC2 = J1-14
FlexTimer 0 - channel 0 = 24.9% low PTC1 = J1-5
FlexTimer 0 - channel 4 = 12.9% low PTD4 = J6-4
FlexTimer 0 - channel 5 = 2.0% low PTD5 = J6-5
I have attached the binary which can be loaded to the FRDM-K64F to verify.
On its VCOM command line menu the I/O menu (3) can be used to view the FlexTimer registers and check with yours to possibly identify your issue.
This is the display showing registers of interest:
Input/Output menu
up go to main menu
md Memory Display [address] [<l>|<w>|<b>] [num]
mm Memory Modify [address] [<l>|<w>|<b>] [val]
mf Memory Fill [address] [<l>|<w>|<b>] [val] [num]
sd Storage Display {as md}
sm Storage Modify {as mm}
sf Storage Fill {as mf}
se Storage Erase [address] [len-hex]
save Save port setting as default
help Display menu specific help
quit Leave command mode
#md 40038000 l 16
Memory Display
0x40038000 0000008f 00002191 000021e7 000000a4 ......!...!.....
0x40038010 00000871 000000a4 000012c0 000000a4 ...q............
0x40038020 000017f0 000000a8 000006c8 000000a4 ................
0x40038030 0000045f 000000a4 000000ad 00000000 ..._............
Mark
Sorry for the late response, I got caught up on other projects. Moving back to this, i manually set the registers rather than letting processor expert handle it, and it allowed me to change the frequencies on the fly. I am unsure why processor expert doesn't let you do this already, but i suspect they have some reason
-Thanks for the help
Nate Hinshaw
Input/Output menu
up go to main menu
#md 40038000 l 16
Memory Display
Mark
All PWM outputs on a FlexTimer share a common frequency and can each have differnet mark-space ratio.
You may prefer to set up all before enabling the counter to avoid any complications.
You may get some ideas from http://www.utasker.com/docs/uTasker/uTaskerHWTimers.PDF.
Mark
