We are working with KSZ8041NL for our requirement with K61 Controller.
when we are connecting the Ethernet cable to the Jack the two status LED’s simultaneously go ON and OFF continuously as long it is connected. And the link is not established between Host PC.
Can any suggest what could be the problem
解決済! 解決策の投稿を見る。
hello Mark,
Thanks for the Reply.
we have shorted out the problem. the problem was because of the jack. once when we replaced the jack it worked.
Thanks and regards,
MANI
The LEDs connected to the KS8041NL are controlled by the KS8041NL itself and not the Kinetis. Check the strap inputs which define the meaning of the LEDs - blinking LEDs usually means that there is activity but in your case it sounds that they may not be working in defined modes (there are some reserved modes that should be avoided). Generally check all strap inputs because strapping to an incorrect mode may also cause unexpected behaviour.
Check that your SW can communicate with the KS8041NL via the management port and check also the register settings to ensure that it is not, for example, strapping to isolation mode (or similar.
Mark
hello Mark,
Thanks and regards,
MANI
