Interrupt Port Code Generation in KDS2.0 for KL25
youngcheolsong
i designed USB device using MKL25Z128VLK4 with KDS 2.0 .
i want to use the PTA4/NMI port(pin 30) to GPIO Interrupt input.
However the generated code is not correct to use for GPIO interrupt input.
it is different from the generated code by the CodeWarrior 10.4.
below is the different part between KDS2.0 and CW10.4.
<CW10.4>
  /* Clear interrupt status flag - w1c */
  PORTA_ISFR = PORT_ISFR_ISF(0x10);
  /* Initialization of Port Control registers */
  /* PORTA_PCR4: ISF=0,IRQC=0x0B,MUX=1 */
  PORTA_PCR4 = (uint32_t)((PORTA_PCR4 & (uint32_t)~(uint32_t)(
                PORT_PCR_ISF_MASK |
                PORT_PCR_IRQC(0x04) |
                PORT_PCR_MUX(0x06)
               )) | (uint32_t)(
                PORT_PCR_IRQC(0x0B) |
                PORT_PCR_MUX(0x01)
<KDS2.0>
  /* PORTA_PCR4: ISF=0,MUX=7 */
                PORT_PCR_ISF_MASK
               )) | (uint32_t)(
                PORT_PCR_MUX(0x07)
Could you help me to use KDS2.0 ?
Original Attachment has been moved to: KDS20_ExtIntLdd9.c.txt.zip
Original Attachment has been moved to: CW104_ExtIntLdd9.c.txt.zip
Labels (2)
david_diaz
The following document could be useful for you:
https://community.freescale.com/docs/DOC-104352
This document explains the interrupt handling mechanism of KSDK platform and how to use it for baremetal KSDK projects.
Have a great day.
Best Regards, :smileyhappy:
David Diaz.
marek_neuzil
Thank you for reporting of this issue. The ExtInt_LDD component in KDS 2.0.0 contain a bug. I will report this defect to the responsible development team.
Marek Neuzil
