Recently i've been trying to implement non-blocking I2C transfers on my FRDM-k22f but i'm struggling to make proper transfers.
As example i'm trying to send slave adress, register address and 2 data bytes but at the end i end up with 5 bytes instead of 4. I double check and i write to data register only 4 times so it seems analyzer sees random states on the bus as a byte?
I checked how much interrupts i get and there is 1 caused by STARTF, 4 caused by TCF and one by STOPF which seems to correct using this way of thinking:
1. startf - slaveaddress
2. regaddress
3. data
4. data
5. no data to send - generate stop condition
6. stopf interrupt
Now the problem starts because even i got interrupt by stopf i cannot get correct stop condition on the bus?
At 5th interrupt i use my I2C_stop function to generate stop condition:
void I2C_stop(I2C_Type *base)
base->C1 &= ~(I2C_C1_MST_MASK|I2C_C1_TX_MASK|I2C_C1_TXAK_MASK);
That's how it looks on analyzer:
Any ideas what might be wrong? I followed block schematic from k22f manual to properly handle interrupts but it's still not enough to get it going.
已解决! 转到解答。
Hi Brian Smith,
From your description, I think your problem still in the software side.
I highly recommend you refer to the official SDK code, which can be downloaded from this link:
Welcome | MCUXpresso SDK Builder
If you want to generate 4 times clock, you can just send 4 times in the code.
You can check the official I2C code at first, if the official code also have problem in your side.
Just let me know.
Kerry
Hi Brian
Take a look at appendix A of http://www.utasker.com/docs/uTasker/uTasker_I2C.pdf to see the I2C interrupts and states (use the non-buffered reference for the K22).
Also try https://github.com/uTasker/uTasker-Kinetis since it includes I2C simulation which also aids in tracing the operation, interrupts and identifying what may not yet be correct.
Did you write the I2C_stop() function or is it from a library? Resetting the TX bit is possibly a mistake.
Mark
Complete Kinetis solutions for professionals, training and support: http://www.utasker.com/kinetis.html
Kinetis K22:
- http://www.utasker.com/kinetis/FRDM-K22F.html
- http://www.utasker.com/kinetis/TWR-K22F120M.html
- http://www.utasker.com/kinetis/BLAZE_K22.html
- http://www.utasker.com/kinetis/tinyK22.html
Problem is that i clock is generated 5 times even i write to Data register only 4 times, no read operation and afaik only write/read operations to data registers actually generate clock? I will try to make it without start and stop interrupts as in single buffered from your pdf and let you know if that helped.
I2C stop is my own but i tried with and without resetting TX bit, result is almost the same, value of extra byte at the end is just different.
Hi Brian Smith,
Just let me know.
Kerry
