I am trying to interface FRDM-STBC-AGM01 kit with my controller using SPI interfacing. Is there any SLAVE address provided for FXLS8471Q, for SPI interfacing? While I2C interfacing Slave address. No any issue with I2C for same.
ソリューションへジャンプ
2,360件の閲覧回数
rajendramemane
I am trying to interface FRDM-STBC-AGM01 kit with my controller XC2287 using SPI interfacing.
2,255件の閲覧回数
Hui_Ma
I2C master need to know I2C slave address to get the data from I2C slave.
SPI master doesn't need the address, which using chip select to get data from SPI slave.
Ma Hui
4 返答(返信)
2,256件の閲覧回数
Hui_Ma
Ma Hui
2,255件の閲覧回数
rajendramemane
FRDM-STBC-AGM01 sensor have 2 sensors (Accell+Magn,Gyro). Then how do we confirm that whether selected SLAVE is "Accell+Magn." or "Gyro".
2,255件の閲覧回数
Hui_Ma
Please refer below FRDM-STBC-AGM01 RevC schematics:
The two sensor as I2C slave with different I2C slave address (check the red block for the I2C slave address).
Wish it helps.
Ma Hui
2,255件の閲覧回数
rajendramemane
Yes, Thanks for the support.
