How to read Internal Registers of KL25Z Freedom
1,440 次查看
nidhinvarghese
How can the Internal Registers of Freedom KL25Z be read ?
My aim is to read the MCG and SIM internal registers and print the value through a putty terminal on PC screen. Through which the internal status of Controller is understood.
1,192 次查看
mjbcswitzerland
Specialist V
Load the binary at
http://www.utasker.com/kinetis/FRDM-KL25Z.html
Then you can read all internal registers out over the UART.
Just find the register address and size - eg. SIM block is at 0x40047000
"md 4004700 l 100" (in the I/O menu) will print out 100 long word contents from the start of the block.
If you need the code to do it just get it from the uTasker project.
Mark
Kinetis for professionals: http://www.utasker.com/kinetis.html
