FlexBus K64 with MRAM
739件の閲覧回数
fshah30
Hello, I am interfacing MCU K64FN1M0VLQ12 with MRAM MR2A16ACMA35.
1- Multiplex mode or non multiplex mode is fast?
2- In Multiplex mode, 16bit address and 16bit data, what are the connections required between MCU and MRAM?
728件の閲覧回数
jingpan
Hi @fshah30 ,
1. They are same.
2. FB_AD[1:18] <=Latch=>A[0:17];
    FB_AD[0:15]<==>D[0:15]
    ALE <->Latch ALE
    MRAM UB&LB can connect to ground.
   You can refer to AN4393 for other pins.
Jing
729件の閲覧回数
jingpan
Hi @fshah30 ,
1. They are same.
    ALE <->Latch ALE
Jing
