Dear all,
We need to "save" some post-programming parameters and therefore we would like to be able to use part of the Flash memory as if it were an EEprom.
I can't find any documentation or examples, can you point me to something to help me ?
Thanks in advance.
Andrea
已解决! 转到解答。
Hi Andrea
See the parameter system in http://www.utasker.com/docs/uTasker/uTaskerFileSystem_3.PDF
The code for this in in the free open source uTasker project on Github and is compatible with KL14, plus also allows you to simulate the chip and the internal flash operations.
Mark
Kinetis: http://www.utasker.com/kinetis.html
Kinetis KL25, KL26, KL27, KL28, KL82, KL43, KL46
- http://http://www.utasker.com/kinetis/FRDM-KL25Z.html
- http://www.utasker.com/kinetis/TWR-KL25Z48M.html
- http://www.utasker.com/kinetis/FRDM-KL26Z.html
- http://www.utasker.com/kinetis/TEENSY_LC.html
- http://www.utasker.com/kinetis/FRDM-KL27Z.html
- http://www.utasker.com/kinetis/Capuccino-KL27.html
- http://www.utasker.com/kinetis/FRDM-KL28Z.html
- http://www.utasker.com/kinetis/FRDM-KL82Z.html
- http://www.utasker.com/kinetis/FRDM-KL43Z.html
- http://www.utasker.com/kinetis/TWR-KL43Z48M.html
- http://www.utasker.com/kinetis/FRDM-KL46Z.html
- http://www.utasker.com/kinetis/TWR-KL46Z48M.html
For less questions and faster, cheaper developments: try uTasker for Kinetis
Hi Andrea
Mark
