I am new to Freescale Controller , Past One month i am trying to Blink one LED in FRDM Kit but i was not able to program.
i am using CodeWarriors Studio. i downloaded SREC precompiled example. and i drag that srec file into Open SDA port, its working file. But i am not able to make that blinking application in CodeWarriors. i did not get how to make such kind of srec application. so where i can get the project source files for srec pre compiled example..? can any one help..? I am struck with FRDM-KL25L... please help me
已解决! 转到解答。
Thank you ! Erich but one thing , i like to write code without using of Processor Expert because If i use PE ,the output srec file size will be more than 1MB. can you tell me any other examples..?
Please verify if you really produce a S19 file (and not something else). I have created many Processor Expert applications, and the S19 file is only few KBytes.
See Optimizing the Kinetis gcc Startup | MCU on Eclipse which produces less than 300 bytes of code.
Hi , This in an example project output files. here "SREC" file size is more than 1MB , why two type of out files are here (hex and srec). If i drag the HEX file into open SDA port it working now..
Hi Erich,
Finally i done my LED Blinking Project ! This is my code given below..
main(){
PE_low_level_init();
while(1){
Bit1_PutVal(0);
delay();
Bit1_PutVal(1);
delay();
AS1_SendBlock(NULL,"ashok",5);
Here i added UART components. but UART not working.. can you help me..
my configuration for UART is given below...
