Can't get this to work
695 次查看
neilporven
Senior Contributor I
The following is an example from the FatFs website:
FRESULT set_timestamp (
  char *obj,  /* Pointer to the file name */
  int year,
  int month,
  int mday,
  int hour,
  int min,
  int sec
  FILINFO fno;
  fno.fdate = (WORD)(((year - 1980) * 512U) | month * 32U | mday);
  fno.ftime = (WORD)(hour * 2048U | min * 32U | sec / 2U);
  return f_utime(obj, &fno);
If I try to use WORD, the compiler throws the following error:
called object 'WORD' is not a function or function pointer
How can I do the typecast WORD?
Thanks you,
Neil
496 次查看
kerryzhou
Hi Neil Porven,
    If you download the Fatfs source code from its official website:
FatFs - Generic FAT File System Module
  You will find a header file named as: integer.h
The content in the integer.h is:
#ifndef _FF_INTEGER
#define _FF_INTEGER
#ifdef _WIN32    /* FatFs development platform */
#include <windows.h>
#include <tchar.h>
typedef unsigned __int64 QWORD;
#else            /* Embedded platform */
/* These types MUST be 16-bit or 32-bit */
typedef int                INT;
typedef unsigned int    UINT;
/* This type MUST be 8-bit */
typedef unsigned char    BYTE;
/* These types MUST be 16-bit */
typedef short            SHORT;
typedef unsigned short    WORD;
typedef unsigned short    WCHAR;
/* These types MUST be 32-bit */
typedef long            LONG;
typedef unsigned long    DWORD;
/* This type MUST be 64-bit (Remove this for C89 compatibility) */
typedef unsigned long long QWORD;
#endif
#endif
So, you can include the integer.h in your set_timestamp function file.
Wish it helps you!
If you still have question, please contact me!
Jingjing
496 次查看
JHinkle
WORD in the code above ..
#define WORD  unsigned long
Hope that helps.
Joe
496 次查看
JHinkle
I noticed in FatFS that WORD is some places was actually referring to the WORD size of the micro -- Thats why I gave you a 32 bit value.
Looking at the maximum values for date and time from the equations you could also place the values into unsigned short int (16 bit).
I don't use a realtime clock -- so I fake a date/time based on the number of time tics since the micro started.
Here's my code.
dword xTaskGetTickCount(void);
DWORD get_fattime (void)
    dword TM = xTaskGetTickCount(); // this is tics
    word days, hours, min, sec;
    TM *= portTICK_PERIOD_MS;   // now have msec
    TM /= 1000;                 // now seconds
    days = TM / (60 *60 *24);
    TM -= days * (60 * 60 * 24);
    hours = TM / (60 * 60);
    TM -= hours * (60 * 60);
    min = TM / 60;
    TM -= min * 60;
    sec = TM;
    if(sec > 60)
        sec = 0;
    return      ((DWORD)(2016 - 1980) << 25)    // Year 2014
            | ((DWORD)7 << 21)                // Month 7
            | ((DWORD)(10+days) << 16)                // Mday 10
            | ((DWORD)hours << 11)                // Hour 16
            | ((DWORD)min << 5)                // Min 0
            | ((DWORD)sec >> 1);                // Sec 0
The DWORD is from FatFS and is defined as
#define DWORD unsigned long.
Joe
