aun cuando oprimo el boton reset para entrar en modo bootloader ,mi pc tampoco lo reconoce ,alguien sabe a que se debe este problema?
In the community, please write the question in English.
I use the translation tool to find that you have problems when use the FRDMK82 opensda, do you intall the P&E driver at first?
Please download the driver from this link:
PEmicro | Experts in Embedded tools for Flash Programming and Development
Please download the driver and install it, then try it again.
BTW, do you use the win10 system?
If yes, you need to update the on board K20 code, please find more details from this link:
OpenSDA Serial and Debug Adapter | NXP
Wish it helps you!
Kerry
