BUG? usb ksdk 1.0.0 dev_get_xd response not checked
965件の閲覧回数
csjc
see KSDK_1.0.0\usb\usb_core\device\sources\controller\usb_dev.c:
in usb_device_recv_data() and usb_device_send_data()
the call to get a transfer descriptor is intended to populate xd_ptr {which is dereferenced without check in usb_device_recv_data() and usb_device_send_data()}
example:
    if (((usb_dev_interface_functions_struct_t*)\
        usb_dev_ptr->usb_dev_interface)->dev_get_xd != NULL)
        error = ((usb_dev_interface_functions_struct_t*)\
            usb_dev_ptr->usb_dev_interface)->dev_get_xd(usb_dev_ptr->controller_handle, &xd_ptr);
    else
        #if _DEBUG
            printf("usb_device_send_data: DEV_GET_XD is NULL\n");
        #endif
        return USBERR_ERROR;
    OS_Mutex_lock(usb_dev_ptr->mutex);
    /* Initialize the new transfer descriptor */
    xd_ptr->ep_num = ep_num;
    xd_ptr->bdirection = USB_SEND;
    xd_ptr->wtotallength = size;
    xd_ptr->wstartaddress = buff_ptr;
    xd_ptr->wsofar = 0;
    xd_ptr->bstatus = USB_STATUS_TRANSFER_ACCEPTED;
        usb_dev_ptr->usb_dev_interface)->dev_send != NULL)
            usb_dev_ptr->usb_dev_interface)->dev_send(usb_dev_ptr->controller_handle, xd_ptr);
ラベル(2)
737件の閲覧回数
Jorge_Gonzalez
Hello Chris:
This bug is already reported to our developers. It should be fixed in the next release of KSDK.
Thanks a lot for your feedback!
Regards!,
Jorge Gonzalez
3 返答(返信)
738件の閲覧回数
Jorge_Gonzalez
Hello Chris:
Regards!,
Jorge Gonzalez
737件の閲覧回数
csjc
is this information available anywhere?
it is not listed in the available latest published KSDK errata: http://cache.freescale.com/files/soft_dev_tools/doc/support_info/KSDK100ER.zip?fasp=1&WT_TYPE=Errata...
737件の閲覧回数
Jorge_Gonzalez
Hi Chris:
This bug was not detected before the publication of that errata document. I think there will be a new version of that document including this one.
Regards!
Jorge Gonzalez
