gmtime
gmtime
1,577 次查看
a8Chcx
I am using KDS3.2.0 for KV58F240 MCU.
I am using cdatm_UTC = gmtime(&time_count); to convert seconds into UTC time.
I can compile and run it, but it won't return from this call.
Can anybody to help me to fix this problem?
Christie
1 回复
1,438 次查看
danielchen
Hi Christie:
The time functions are not implemented . The header file (time.h) is provided for compatibility only.  If you need it, you have to write your own functions.
Just an information: I tested the gmtime with MCUXpresso SDK 2.4.1 with MCUXpresso IDE 10.2.1 and Frdm-k66 board.  I can get the right result.
