cannot install KDS if MCUXpresso is present
692 次查看
gschelotto
Contributor V
I've installed MCUXpresso IDE successfully on my Linux (debian) distribution but KDS installer failed at this point:
It seems that there's a problem with some PEmicro packages.
How can I address this issue? Should I remove the packages from MCUXpresso IDE and then reinstall KDS?
regards,
gaston
530 次查看
Carlos_Mendoza
Hi Gaston,
If MCUXpresso was installed before KDS then use this command to install Kinetis Design Studio:
sudo dpkg -i --force-depends --force-overwrite kinetis-design-studio_3.2.0-1_amd64.deb
Hope it helps!
Carlos Mendoza
Technical Support Engineer
4 回复数
530 次查看
gschelotto
Contributor V
Erich, thanks for the hint but I cannot reproduce the suggested steps. In my case MCUXpresso was installed before KDS and KDS installer is delivered as .deb package instead the MCUXpresso .bin executable file.
Is there another workaround to fix it? (by tacking into account the installation order: 1st MCUXpresso, 2nd KDS IDE)
regards,
gaston
531 次查看
Carlos_Mendoza
Hi Gaston,
Hope it helps!
Carlos Mendoza
530 次查看
gschelotto
Contributor V
It works! thank you Carlos and Erich for your help,
regards,
gaston
530 次查看
BlackNight
Hi Gaston,
the following thread should help you: https://community.nxp.com/thread/447699
I hope this helps,
Erich
