Hey,
I am trying to configure SPI1 on the K82 FRDM board.
I am useing PCS1. On the scope I see a 12 Mhz SCK clocks when my configuration is for 500Khz.
Also I don't see anything on the PCS1 line even though I have it confgured on the pin-mux file.
When using CTAR0 I see an 8 bit clock pattern but data and clock are out of sync.
/** *@brief Initializes the SPI peripheral *@return none */ void SPI_Initialize(void) { uint32_t srcClock_Hz; dspi_master_config_t masterConfig; /* Master config */ masterConfig.whichCtar = kDSPI_Ctar1; masterConfig.ctarConfig.baudRate = TRANSFER_BAUDRATE; masterConfig.ctarConfig.bitsPerFrame = 8U; masterConfig.ctarConfig.cpol = kDSPI_ClockPolarityActiveHigh; masterConfig.ctarConfig.cpha = kDSPI_ClockPhaseFirstEdge; masterConfig.ctarConfig.direction = kDSPI_MsbFirst; masterConfig.ctarConfig.pcsToSckDelayInNanoSec = 1000000000/TRANSFER_BAUDRATE; masterConfig.ctarConfig.lastSckToPcsDelayInNanoSec = 1000000000/TRANSFER_BAUDRATE; masterConfig.ctarConfig.betweenTransferDelayInNanoSec = 1000000000/TRANSFER_BAUDRATE; masterConfig.whichPcs = DSPI_MASTER_PCS_FOR_TRANSFER; masterConfig.pcsActiveHighOrLow = kDSPI_PcsActiveLow; masterConfig.enableContinuousSCK = false; masterConfig.enableRxFifoOverWrite = false; masterConfig.enableModifiedTimingFormat = false; masterConfig.samplePoint = kDSPI_SckToSin0Clock; srcClock_Hz = CLOCK_GetFreq(DSPI_MASTER_CLK_SRC); DSPI_MasterInit(DSPI_MASTER_BASEADDR, &masterConfig, srcClock_Hz); } /** *@brief Writes a byte of data to the SPI bus *@param data Byte data to write on bus *@return result Result of data written on SPI bus. */ char SPI_Write(unsigned char data) { // // unsigned char rdata = 0; // // dspi_transfer_t masterXfer; // // /* Start master transfer */ // masterXfer.txData = &data; // masterXfer.rxData = &rdata; // masterXfer.dataSize = 1; // //masterXfer.configFlags = kDSPI_MasterCtar1 | DSPI_MASTER_PCS_FOR_TRANSFER | kDSPI_MasterPcsContinuous; // // DSPI_MasterTransferBlocking(DSPI_MASTER_BASEADDR, &masterXfer); DSPI_MasterWriteCommandDataBlocking(DSPI_MASTER_BASEADDR, data); return data; }
CLOCK_EnableClock(kCLOCK_PortB); CLOCK_EnableClock(kCLOCK_PortD); /* SPI1 */ PORT_SetPinMux(PORTB, 23U, kPORT_MuxAsGpio); //NRF_IRQ PORT_SetPinMux(PORTB, 9U, kPORT_MuxAlt6); //NRF_CSN PORT_SetPinMux(PORTD, 5U, kPORT_MuxAlt7); //NRF_SCK PORT_SetPinMux(PORTD, 6U, kPORT_MuxAlt7); //NRF_MOSI PORT_SetPinMux(PORTD, 7U, kPORT_MuxAlt7); //NRF_MISO
/* SPI1 */
The demos under dspi folder do not work for me.
I tried the bubble demo under the apps folder and that works.
I also checked with the scope on the PA14, 15, 16, 17 pins where SPI 0 master is allocated and I don't see any signal.
Also for the SPI polling demo nothing shows up under the terminal.
The boot loader for this board ( opensda )is really bad. I have to plug /unplug the board just so that it can load the new firmware.
I based the SPI demo below from the polling SPi example and I still see the issue between MOSI and SCK line. Also the CS line is not active. I have activated the pin under the board file.
http://s000.tinyupload.com/?file_id=45478221156128599200
From what I see this looks like an issue with the bootloader or the KSDK2 HAL.
Di
Hello Di,
Please be sure the correct line connection .
I test the demo of SDK_2.0_FRDM-K82F\boards\frdmk82f\driver_examples\dspi\polling_transfer
it can work well :
from the slaveRxData[] , we can see the salve received the data master send :
we can refer to the "readme.txt"(boards\frdmk82f\driver_examples\dspi\polling_transfer\readme.txt) to connect :
Alice
Hello Alice,
Yes, I am using KSDK 2. This code is based on the demo, but when using this configuration:
I see that the SCK clock and the data from the MISO pins are not synchronized.
Also do I have to control PCS1 manually or does the peripheral take care of that?
I don't see the PCS1 activating when data is coming out of the MISO line.
Di
Hello Di,
In the demo , the CTAR configuration is the same with you,
masterConfig.whichCtar = kDSPI_Ctar0;
so please first run the dome check whether it can work well as you want .
Aobut the PCS , it configured in these code :
when it active, it should be low .
Alice
