Problems with comp.c
1,015 次查看
norbertoj
Hello. I have some problems to get compile the file comp.c. I'm using MQX 4.2 in KDS 3.0.0. I imported bsp, psp and rtcs to KDS. (.kds build). I have in another project my application code. When I compile my application code, I have the next errors in comp. c
I'm using a TWRK60D100M, and I'm using cortex-m gcc-arm.
728 次查看
Hello Norberto,
There is a document about create MQX project on KDS, hope it can helps.
Creating a New MQX RTOS 4.2 project in KDS
Alice
4 回复数
729 次查看
Hello Norberto,
Alice
728 次查看
norbertoj
Hi, I did all steps but I still have errors. Now, I only get the next errors:
I don't know if  my psp is taking the right compiler folder or not
Norberto Jiménez
728 次查看
Hello Norberto,
Have the problem been solved ?
If not , you can send your project to me , i  try it on my side ,
or please tell me how to reproduce the problem .
I recommend you also ask under the document  Creating a New MQX RTOS 4.2 project in KDS
for he maybe know the problem more clearly .
Alice
728 次查看
norbertoj
Hello Alice,
I make my project like your doccument and I change the version of toolchain to 4.9.3 and it works.
Thank you
Alice
Norberto Jiménez
