Problem debugging FreeRTOS with GDB in KDS
961 次查看
amprel
Hello everybody,
I have the following problem. The scenario first:
  • Custom board with Kinetis K10
  • KDS 3.0.0
  • Pemicro Multilink Universal debugger
  • FreeRTOS 9.0.0 (I'm using the GCC / Cortex M3 port)
  • I'm not using Processor Expert
The problem: when debugging a program with FreeRTOS, I can set breakpoints and step through code, but when I try to return from a function by stepping on its last instruction (i.e. closing curly bracket), gdb crashes. In the console I get the following errors:
Unable to go into background mode.
Error communicating to target processor - try a RESET.
PE-ERROR: TARGET IS RUNNING
It looks like something in the stack frame confuses gdb. The same program works as expected if I let it run without debugging. Please note that when I debug a program without FreeRTOS everything works like a charm.
Also, in FreeRTOSConfig.h, I have added the following line:
#define configTASK_RETURN_ADDRESS   0  /* return address of task is zero */
as suggested in the post 'GDB PEMicro Interface Debugging' (nov. 2014).
Thank you in advance for your help, which would be greatly appreciated.
Alex
380 次查看
soledad
could you please try creating a new project according the following document: Creating a FreeRTOS project using KDS and Kinetis SDK Project V2.0
Then please follow the below document:
GDB Debugging with Kinetis Design Studio
Please let me know if this helps.
Sol
