Porting WS2812B code to FRDM-K82F
1,202件の閲覧回数
tishampatidhar
I have been following the tutorial for using FlexIO to drive the custom protocol for WS2812. I have renamed some registers to port to K82F. However I am unsure about porting the register style DMA access to Kinetis SDK style EDMA usage. Any pointers appreciated. My code is available here:
FRDM-K82F_WS2812_Driver/WS2812.c at master · whatnick/FRDM-K82F_WS2812_Driver · GitHub
DMA section is commented out. A review and pull request will enable me to learn and bring the NeoPixel to K82F.
Tishampati Dhar
3 返答(返信)
707件の閲覧回数
marc3l
Thank you for opening this tread; I have the same problem with connecting the Neopixels / WS2812b leds to my FRDM K82F board. As ZhangJennie​ mentioned; I also tried the edma code, and many other (sample)projects to combine it with the work that BlackNight​ made with his WS2812 with FlexIO project. But until now I couldn't light up the Neopixels yet.
If anyone has a solution, please share it! You will be thanked with a lot of colorful light
707件の閲覧回数
tishampatidhar
Hi Marcel,
I have been banging my head against it for a couple of weeks as well.
Implementation obviously requires good understanding of the MCU and we must
be missing some settings. I have made 2 compilable ports from Erichs work
for both SDK 1.3 and 2.0 on github. I would appreciate if you had a look
and fiddled to see if you could get it to work. From my observation so far
the DMA transfer seems to be getting stuck.
Cheers,
Tisham.
707件の閲覧回数
ZhangJennie
HI,
I suggest you go to Welcome to Kinetis Expert | Kinetis Expert
to download SDK_2.0_FRDM-K82F package, then refer edma demo code in this folder:
..\SDK_2.0_FRDM-K82F\boards\frdmk82f\driver_examples\edma
Jennie Zhang
