for the moment OpenSDA driver doesn't support win10
the latest OpenSDA driver v1.11 adds support Windows 8/8.1, MacOS and Linux operating systems.
If you are currently running OpenSDA Bootloader version 1.10 or earlier, you will need to find a Windows XP or Windows 7 PC to perform this update.
for more information, see
can this help you?
Zhang Jun
can this help you?
Zhang Jun
I have KDS v3.0.0 working on Windows 10 :-).
There is that old issue with FRDM board bootloaders that you need to update it using a Windows 7 machine (that's already the case for Windows 8.x).
There is another known problem that the driver might stop working after a while, see P&E Microcomputer Systems
P&E has released a patch for Windows 10 here: http://www.pemicro.com/downloads/download_file.cfm?download_id=460
I hope that helps,
Erich
Erich Thanks;
Starting yesterday I'm using this patch.
The problem with PEmicro in my opinion (???) was that some of the windows updates has effected the driver and this patch solved it.
I don't have experience like you, but I think that Segger J-Link is not stable (stops working?) in windows 10 to.
I have cases that it stops working and new reconnections is required. I'm not sure if it was my fault because I return back to PEmicro (with the patch)
Do you have any feedback?
Shaul
