I am attempting to make use of a system build variable in my C source, in this case it is the build number of the SW being built. This value, 'BUILD_NMBER' is defined among the environmental variables of the host system, and I have confirmed that this variable appears in the list of system build variables within KDS.
Where I'm not sure how to proceed is in incorporate this variable into my C source code. In this case I wish to capture this number in SW such that it can be reported back at runtime as though it were a #define. My project compiles into a binary image that will be running on an embedded device, if that helps at all.
Any advice in how I might do this would be greatly appreciated! Thanks!
-Erik Tidemand
解決済! 解決策の投稿を見る。
In Make:
-DBUILDNUMBER=$(your env build_number)
I explain the process here:
Software Safety: Automatic Serial Number for Test Driven Development. Makefile Tip #0
In Make:
This was the trick I was looking for. Thanks!
-Erik
