KDS file extension issue
AnangBohra
Yesterday I ran into a problem with source file extension in KDS 3.0. I accidentally named my source file to "xyz.C" and no matter what I did, the software would not compile and keep throwing errors.
After couple of hours of going backward and forward, I renamed the file to "xyz.c" and there you go, worked like a charm..
Has anyone come across similar issue?
Btw, I am windows 7, 64bit.
thanks.
BlackNight
Hi Anang,
*.C files are treated as C++ files in Eclipse. See https://mcuoneclipse.com/2016/05/05/assembly-files-in-eclipse-cdt-projects/  on a similar topic.
I hope this helps,
Erich
