Just installed KDS 2.0.0.
Following steps in "Getting Started with Freescale MQX RTOS for Kinetis SDK and Kinetis Design Studio IDE", Doc No: KSDKGSKDSUG.
Sec 2.1: Installing MQX RTOS Task Aware Debugger for GDB plug-in (TAD)
Try to access:
Freescale KDS Update Site - http://freescale.com/lgfiles/updates/Eclipse/KDS
Get error:
Unable to read repository at http://freescale.com/lgfiles/updates/Eclipse/KDS/content.jar
I have verified that this still works with KDS 1.1.0.
Does anyone have a work around for this?
Solved! Go to Solution.
Hi Jeffrey,
I just check this link on my side with kds2.0 it works:
can you please try it again or change another network?
Best Regards.
Zhang Jun
this answer is for you, if it helps, please click on "correct answer" button. thanks!
Hi Jeffrey,
Best Regards.
Zhang Jun
Zhang,
From my home network I am able to access the update site via KDS_2.0.0 just fine.
Thank you,
