Hi everyone,
I am trying to run a demo app that is located in the following folder:
Freescale/KSDK_1.3.0/examples/frdmk64f/demo_apps/usb/host/msd/msd_fatfs/bm/kds
I am not sure if you can run a demo app or if its just use for reference?
I have the FRDM-K64F board and I am using the SDAUSB port to load it. I am not sure if this is
correct? Is that the right port? What should I use to debug it (host_msd_fatfs_bm_frdmk64f debug csmisdap)?
I am getting the following error I am attaching.
Hello Neil,
1. There is a steps guide about how to run this demo code :
KSDK_1.3.0\examples\frdmk64f\demo_apps\usb\host\msd\msd_fatfs\readme.pdf
please refer to it .
2. If still can't work, please tell me when it shows this error , when download ? If yes, please first create a simple
project to debug , check whether it can work well .
3. Just a kind of suggestion, if your project haven't begin, recommend you use the latest version KSDKv2.2 :
Software Development Kit for Kinetis MCUs|NXP
Hope it helps
TIC
Hi Alice,
I tried following the example instructions an running the demo on my FRDM-K64F board, but when I
connect RealTerm (like Hyperterminal) I don't seen anything being sent. I configured RealTerm for
Baud: 115200, Parity: none, Data Bits: 8, Stop Bits: 1, Flow: none.
Do you have to program the FRDM-K64F with an OPEN SDA first before running the demo app?
Neil
Hi Alice,
I use the P&E multilink to load the demo app, but I had to modify the board by cutting the runners
for J5, J8, and J12. I also placed jumpers on these so that if I needed, I can short again. Unfortunately, when I run the demo app, I get nothing on Realterm? I configured Realterm correctly and followed the instructions on the Readme PDFs, which by the way doesn't show pictures on how to properly connect the board or really tell you if certain connectors need to be shorted or not if you using P&E programmer.
I get no errors during compiling so I imagine that the demo is working and debug/linking to the board seems to work fine. There are no errors when I run it and I can tell my cables to the PC are fine.
Can you tell me if I could be doing something wrong?
Can you send me the demo zipped?I
I have two other boards I will test tomorrow in the meantime, I can't continue with
my project until I have at least the demo working.
Neil
Hi Neil,
You haven't use the OpenSDA on board, so which UART port do you used ?
The default code on demo project use the UART0( PTB16 and PTB17 pins), connected to OpenSDA (J26).
I recommend you use the on board debugger (OpenSDA) first .
ALice
Hi Alice,
I followed the instructions for using the OpenSDAv2. I first placed the FRDM-K64F board on bootloader mode, then found the
k20dx128_k64f_if_mbed on the following website: Firmware FRDM K64F - Handbook | Mbed and loaded on the board. I finally
loaded or try to load the demo app msd_host_fatfs_bm_frdmk64f and first tried the debug, then the release version and both
gave me an error.
Here is the console error:
Here is a picture of the new EMBED host file after following the steps of the OpenSDAv2
Let me know if any of these help you understand what is happening?
Thank you,
Neil
Hi Alice,
I was able to figure out the problem. Once I loaded the binary file to the OPENSDAv2, instead of using my
P&E multilink to run the demo, I created a binary file which I dropped inside the MBED file that comes up.
This way I was able to run the demo.
Neil
