Freemaster connect fail
2,027件の閲覧回数
814420552
Dear all,
   when i connect  my board with openSDA, then open freeMaster tool,  boautrate is 115200, when click next step, it happeened the following error, pls  help me, only connect board and pc with USB line (openSDA)
3 返答(返信)
1,931件の閲覧回数
VilemZ
it looks, that you want to connect via UART instead of the OpenSDA. For connection via UART, you need have the running Freemaster in the board too.
If you want to use only OpenSDA, please select the highlited option in wizard.
And after then, you will see options of the debug connections:
Vilem
1,931件の閲覧回数
814420552
hello, whether has some manual or document for how to use this tool(FreeMaster)?
wish you can share it to me, thanks very much!!
1,931件の閲覧回数
VilemZ
you can find all documents on the NXP web page: FreeMASTER Run-Time Debugging Tool | NXP
Vilem
