Deinstalltion FreeMaster 3.2
997 次查看
peta
My installation of FreeMaster 3.2 was aborted. When reinstalling, I get an error message that the software is already present and an upgrade is not possible. How can I install the software again?
Peter
975 次查看
iulian_stan
Just to make sure - are you able to access hidden folders on your system ? By default, Zero G Registry is a hidden folder and may not show up in explorer/search window for users with limited privileges.
If you have admin rights on your PC, could you update system options to show hidden folders and try searching for the folder/file on your system disk.
A few additional questions:
  • Are there any remaining files from the previous installation on you disk (ex: C:/NXP/FreeMASTER 3.2/) ?
  • Does FreeMASTER 3.2 shows up in Program and Features under Control Panel ?
4 回复数
983 次查看
peta
Hi julian,
thanks for the quick replay.
I don´t have this folder or the file on my notebook.
Kind regards
Peter
976 次查看
iulian_stan
971 次查看
peta
Okay, I could fix it. Installation is done, thanks for your help. Best regards Peter
987 次查看
iulian_stan
Hi Peter,
Could you check this post and let us know if that works for you.
King regards,
Iulian
