Hello , it's there a way to check the Tresos license file expiration date without using the GUI Elektrobit Client License Administration.exe, basically I would like to automate the process and set a alert if the license will expire soon... I was searching for a example_license.txt in which i can see the license expire date..
Solution:
Found the solution if anyone is having this problem :
Inside EB>EB_Client_License_Administrator_XXX > 1.25>x64 use the cmd appaductil.exe -view > license.txt , it will generate a license automatically.
