Ethernet problem M52233demo, send double messages
1,273件の閲覧回数
VeronicaFNX
Hello, i have a problem with ethernet. When i use the eth_stub_send() function the message is always sent twice! But i know the function is only called once. I send double messages and I don't know the solution. Can you help me? Thanks. Regards
Veronica
361件の閲覧回数
mjbcswitzerland
Specialist V
Veronica
Try using two tx buffer decriptors rather than one (which I assume you presently have). My experience is that a frame in a single buffer description is always sent twice, which never happens when more than one buffer is available. You can also prepare the frame to be transmitted to be chained in 2 buffer descriptions (eg. IP part in first and UDP etc. part in second). which shoud stop it happening.
If you find another solution, please also let us know!!
Mark Butcher
Message Edited by mjbcswitzerland on 2007-02-0607:28 PM
