CODEWARRIOR, COLDFIRE & ETHERNET
2,848件の閲覧回数
area3
Hi All,
I need to develop a software that works with ethernet controller of a 5282 board (ColdfireV2). I'm using Codewarrior 6.1 but isn't an ethernet library (or I don't found it).
Anyone can help me to find a correct and functionally library for TCP function?
Thanks all.
2 返答(返信)
1,595件の閲覧回数
Nouchi
Senior Contributor II
First you should update your CW6.1 version to 6.3:
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=COLDFIRE-UPDATES&parentCode=null&node...
You could have a look to internich tcp/ip lite for the mcf52235 wich could be ported for 5282
https://www.freescale.com/webapp/Download?colCode=COLDFIRE_TCPIP_LITE&prodCode=MCF52235&nodeId=01624...
otherwise, there's many solutions in the open source world, with GNU tools and OS likes µCLinux, RTEMS, eCos, FreeRTOS.org and maybe many others
Emmanuel
1,595件の閲覧回数
CrasyCat
Specialist III
Hello
Did you check the Freescale MCF8252 product page? Look at following URL:
There are a couple of Protocol stacks available for download there.
I hope this helps.
CrasyCat
