ERROR:There are errors in this bean, it is impossible to generate code
IRQ0~IRQ3 are well enabled but IRQ4~IRQ16 are can't enable
Would you give me advice about this problem?
Dear Customer,
I am sorry but we cannot reproduce the issue. Could you please closer describe the steps leading to the hang-up. What version of operting system do you use? Do you install and run the Processor Expert with the Administrator rights? Does the compilation stop after compiling the first file?
best regards
Petr Hradsky
UNIS
