It is possible to use an assembler only project. Please see the attached assembler example project that has a main.asm, assembler sources and a linker configuration file linker.lcf. You can use it as an example and modify your existing project to have similar settings.
I hope this helps,
Black
I have to agree 'vfr'. I don't want anything to do with 'C' in my projects, yet with the Coldfire you seem to be forced to. I had been using CW on the HC08 too and have spent sometime trying to figure out how to exclude any 'C' references for the Coldfire V1, seems it's not possible, it would be nice to know why this is the situation.
Cheers,
Ross
