Hi Jane,
I had got the same error when I tried to use the Flash Programmer.
But when I tried to do the same in a newly created project, it worked.
Also,
Are you sure that your Flash chip is OK?..Check by using a stand-alone program.
Also take care in the CFG file you are using....
One more thing.....
I remember that, way down our project, the USB-TAP had some allergy with FLASH(I do not exactly remember the issue....)....Try using a different Emulator.....PEMICRO-USB is more stable....
Hope this helps,
Venki
Hello Jane,
As Venki noted, the CFG (Target Initialization File) is very important. If the CodeWarrior Flash Programmer works well when run on Windows but not when run on Linux then I suspect the CFG file on Linux is incorrect. Try comparing the two files (Windows and Linux CFG files) and look for mismatches -- if you find any discrepancies, go with the Windows version. I hope this helps.
Ron
