CAST a CHAR array as a structure
4,989件の閲覧回数
WOLF
i have the following struct code
struct record
 char Name[21];
 char date[3];
 char array[24];
 char *ptr=array;
 struct record *read_record;
 array[0]=1;
 array[1]=2;
 read_record = (struct record*) ptr;
printf(" %c %c\n",read_record->Name[0],read_record->Name[1] );
this should display 1 and 2, but display nothing.
can anyone expalin what i'm doing wrong?
thanks
 return 0;
タグ(1)
2 返答(返信)
711件の閲覧回数
CompilerGuru
First let me mention that normally such casts and similar things should not be done at all.
In your case, I guess the problem is that you print the (non printable) character with value 1, and not '1'.
E.g.:
 array[0]='1';
 array[1]='2';
But again, I have to have a good reason before I do such casts.
(or did you intend:
>printf(" %i %i\n",read_record->Name[0],read_record->Name[1] );
711件の閲覧回数
WOLF
Decided to do it, using a different aproach.
thanks anyway for the help
