Hello team NXP,
We built the custom BSC9132 board but not changed the ddr3 chips that is used in the bsc9132qds board. Only layer stack changed because of this execution of BSC9132QDS_init_core stops infinitely with log
cmdwin::wait 50
cmdwin::eclipse::config runcontrolsync on
cmdwin::stop
ccs_stop_core
coreh = [serverh:0;cc_index:0;chain_pos:1]
ccs_stop_core; ccs_error = -2147418099
Error message: ELF is not in expected HALT mode
then i thought we should run the ddr validation on this but non of the test are getting passed on the board.
each test failed with the following error.
DDR enable error: timeout occurred while waiting for SDRAM_CFG_2[D_INIT]
ddr validation project set up is working(i.e validation happens and gives good configurations) on the bsc9132qds(evaluation board) since our board has same ddr chips i am using the same project for our board also.
Please someone help me to resolve this problem
Patil
Hello manju patil,
In your console log, it seems that there is problem to stop the core through JTAG, it is often caused by the improper JTAG interface design.
Please refer to page 6 in the attached PPT to check JTAG hardware design, please ensure HRESET not tied to TRST, HRESET to the processor exclusive to COP/JTAG header.
Regarding DDRv tool using on the custom board, please make sure the clock configuration is valid and the DDR bus frequency configured in DDRv tool is the same as the target board.
If your problem remains, would you please capture the DDR CCS log to me to do more investigation?
When you use DDRv tool to connect to the target board, CodeWarrior connection Sever will be invoked automatically, please open it at the right bottom of the task bar, then type command "log v" in CCS console. In DDRv, please connect to the target board again and click "Start Validation", the low level communication log between DDRv and the target board will be captured in the CCS console.
Yiping
Hello yipingwang,
I could not find the PPT for the JTAG design, please do check.
i am attaching the ddr validation logs here please do check and let me know what is going wrong here,
#5 repeats
reg: 0F
reg: F7
read_memory(coreh.{serverh=0,cc_index=0,chain_pos=1},
addr.{addr_hi=0x00000000,addr_lo=0xFF702114,size=1,space=0},count=4,*data)
data: 24 40 10 10
read_register(coreh.{serverh=0,cc_index=0,chain_pos=1},index=30000,count=1,size=8,*reg)
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702E20,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702E24,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702E28,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702E40,size=1,space=0},count=4,*data)
data: 00 00 00 80
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702E44,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702E48,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702E4C,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702E50,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702E54,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702E58,size=1,space=0},count=4,*data)
data: 00 01 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F00,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F04,size=1,space=0},count=4,*data)
data: 00 00 21 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F08,size=1,space=0},count=4,*data)
data: 00 00 00 0E
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F0C,size=1,space=0},count=4,*data)
data: 14 00 00 60
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F10,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F14,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F18,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F1C,size=1,space=0},count=4,*data)
data: 02 02 02 02
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F20,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F24,size=1,space=0},count=4,*data)
data: 02 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F28,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F2C,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F30,size=1,space=0},count=4,*data)
data: 00 00 00 15
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F34,size=1,space=0},count=4,*data)
data: 00 0C 00 20
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F38,size=1,space=0},count=4,*data)
data: 00 0E 0E 0E
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F3C,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F40,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F44,size=1,space=0},count=4,*data)
data: 0C 03 02 80
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F48,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F4C,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F50,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F54,size=1,space=0},count=4,*data)
data: 24 44 44 44
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F58,size=1,space=0},count=4,*data)
data: 44 44 44 44
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F5C,size=1,space=0},count=4,*data)
data: 44 44 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F60,size=1,space=0},count=4,*data)
data: 00 40 00 40
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F64,size=1,space=0},count=4,*data)
data: 00 40 00 40
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F68,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F6C,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F70,size=1,space=0},count=4,*data)
data: 00 40 00 40
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F74,size=1,space=0},count=4,*data)
data: 00 40 00 40
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F78,size=1,space=0},count=4,*data)
data: 00 40 00 40
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F7C,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F80,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F84,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F88,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F8C,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F90,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F94,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F98,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F9C,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702FA0,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702FA4,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702FA8,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702FAC,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702FB0,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702FB4,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702FB8,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702FBC,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702FC0,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702FC4,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702FC8,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702FCC,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702FD0,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702FD4,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702FD8,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702FDC,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702FE0,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702FE4,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702FE8,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702FEC,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702FF0,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702FF4,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702FF8,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702FFC,size=1,space=0},count=4,*data)
data: 00 00 00 00
CCSAPI connection #1 from DESKTOP-CLV1MBM closed at Mon Feb 18 16:07:29 2019
CCSAPI connection #1 accepted from DESKTOP-CLV1MBM at Mon Feb 18 16:07:30 2019
check_min_version(serverh=0,*version)
api version: 00000004 00000006
available_connections(serverh=0,*count,*cc)
connections: {0,70,0xa9fefa33}
cc_version(serverh=0,cc_index=0,index=0,*version)
config_chain(serverh=0,cc=0,count=1,*devlist,*generic)
devlist: mpc9132
get_config_chain(serverh=0,cc=0)
*** unhandled(command=163) ***
config_server(config_reg=3,config_data=0x00000001)
reset_to_debug(serverh=0,cc=0)
stop_core(coreh.{serverh=0,cc_index=0,chain_pos=1})
read_reg(coreh.{serverh=0,cc_index=0,chain_pos=1},index=2032,count=1,*reg)
reg: FFFFFFFC
in(coreh.{serverh=0,cc_index=0,chain_pos=1},count=8,addr={0x00000000,0x00002711,0x00000000,0x00000000}
data: 49 34 05 35 FD D0 2B 90
read_reg(coreh.{serverh=0,cc_index=0,chain_pos=1},index=8,count=1,*reg)
reg: 00000000
core_run_mode(serverh=0,*mode)
reg: 00
#5 repeats
reg: 0F
reg: F7
write_memory(coreh.{serverh=0,cc_index=0,chain_pos=1},
addr.{addr_hi=0x00000000,addr_lo=0xFF700C08,size=4,space=0},count=4,*data)
data: 00080000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF700C10,size=4,space=0},count=4,*data)
data: 80F00013
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF700C28,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF700C30,size=4,space=0},count=4,*data)
data: 80F0001E
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702000,size=4,space=0},count=4,*data)
data: 0000007F
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702008,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702010,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702018,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702080,size=4,space=0},count=4,*data)
data: 80014402
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702084,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702088,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF70208C,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF7020C0,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF7020C4,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF7020C8,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF7020CC,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702100,size=4,space=0},count=4,*data)
data: 00070000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702104,size=4,space=0},count=4,*data)
data: 80330104
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702108,size=4,space=0},count=4,*data)
data: 5F5B0644
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF70210C,size=4,space=0},count=4,*data)
data: 0FA89190
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702110,size=4,space=0},count=4,*data)
data: 470C0008
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702114,size=4,space=0},count=4,*data)
data: 24401010
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702118,size=4,space=0},count=4,*data)
data: 00061420
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF70211C,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702120,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702124,size=4,space=0},count=4,*data)
data: 0C30030C
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702128,size=4,space=0},count=4,*data)
data: DEADBEEF
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702130,size=4,space=0},count=4,*data)
data: 01800000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702148,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF70214C,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702160,size=4,space=0},count=4,*data)
data: 00000001
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702164,size=4,space=0},count=4,*data)
data: 02401400
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702170,size=4,space=0},count=4,*data)
data: 89080600
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702174,size=4,space=0},count=4,*data)
data: 8655F600
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF70217C,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702180,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702184,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702190,size=4,space=0},count=4,*data)
data: 07070708
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702194,size=4,space=0},count=4,*data)
data: 08080900
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702200,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702204,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702208,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF70220C,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702210,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702214,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702B20,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702B24,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702B28,size=4,space=0},count=4,*data)
data: 80000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702B2C,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702BF8,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702BFC,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702D00,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702D20,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702D24,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702D28,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702D2C,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702D30,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702D34,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702D38,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702D3C,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702D40,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702D44,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702E00,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702E04,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702E08,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702E20,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702E24,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702E28,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702E40,size=4,space=0},count=4,*data)
data: 8000119D
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702E44,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702E48,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702E4C,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702E50,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702E54,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702E58,size=4,space=0},count=4,*data)
data: 00010000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: C70C0008
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 80
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 01 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 21 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 0E
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 14 00 00 60
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 02 02 02 02
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 02 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 15
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 0C 00 20
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 0E 0E 0E
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 0C 03 02 80
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 44 44 44
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 44 44 44 44
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 44 44 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 40 00 40
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 40 00 40
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 40 00 40
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 40 00 40
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 40 00 40
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
CCSAPI connection #1 from DESKTOP-CLV1MBM closed at Mon Feb 18 16:07:44 2019
CCSAPI connection #1 accepted from DESKTOP-CLV1MBM at Mon Feb 18 16:07:46 2019
devlist: mpc9132
reg: FFFFFFFC
reg: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00080000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 80F00013
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 80F0001E
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 0000007F
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 80014402
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00070000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 80330104
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 5F5B0644
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 0FA89190
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 470C0008
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24401010
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00061420
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 0C30030C
reg: 00
#5 repeats
reg: 0F
reg: F7
data: DEADBEEF
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 02000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000001
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 02401400
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 89080600
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 8655F600
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 07070708
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 08080900
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 80000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 8000119D
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00010000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: C70C0008
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 80
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 01 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 21 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 0E
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 14 00 00 60
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 02 02 02 02
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 02 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 15
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 0C 00 20
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 0E 0E 0E
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 0C 03 02 80
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 44 44 44
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 44 44 44 44
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 44 44 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 40 00 40
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 40 00 40
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 40 00 40
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 40 00 40
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 40 00 40
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
CCSAPI connection #1 from DESKTOP-CLV1MBM closed at Mon Feb 18 16:08:01 2019
CCSAPI connection #1 accepted from DESKTOP-CLV1MBM at Mon Feb 18 16:08:02 2019
devlist: mpc9132
reg: FFFFFFFC
reg: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00080000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 80F00013
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 80F0001E
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 0000007F
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 80014402
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00070000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 80330104
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 5F5B0644
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 0FA89190
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 470C0008
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24401010
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00061420
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 0C30030C
reg: 00
#5 repeats
reg: 0F
reg: F7
data: DEADBEEF
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 02000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000001
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 02401400
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 89080600
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 8655F600
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 07070708
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 08080900
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 80000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 8000119D
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00010000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: C70C0008
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 80
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 01 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 21 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 0E
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 14 00 00 60
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 02 02 02 02
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 02 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 15
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 0C 00 20
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 0E 0E 0E
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 0C 03 02 80
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 44 44 44
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 44 44 44 44
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 44 44 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 40 00 40
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 40 00 40
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 40 00 40
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 40 00 40
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 40 00 40
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
CCSAPI connection #1 from DESKTOP-CLV1MBM closed at Mon Feb 18 16:08:23 2019
CCSAPI connection #1 accepted from DESKTOP-CLV1MBM at Mon Feb 18 16:08:24 2019
devlist: mpc9132
reg: FFFFFFFC
reg: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00080000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 80F00013
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 80F0001E
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 0000007F
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 80014402
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00070000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 80330104
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 5F5B0644
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 0FA89190
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 470C0008
read_register(coreh.{serverh=0,cc_index=0,chain_pos=1},index=30000,count=1,size=8,*reg)
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24401010
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00061420
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 0C30030C
reg: 00
#5 repeats
reg: 0F
reg: F7
data: DEADBEEF
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 02000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000001
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 02401400
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 89080600
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 8655F600
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 07070708
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 08080900
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 80000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 8000119D
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00010000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: C70C0008
reg: 00
#5 repeats
reg: 0F
reg: F7
read_memory(coreh.{serverh=0,cc_index=0,chain_pos=1},
addr.{addr_hi=0x00000000,addr_lo=0xFF702114,size=1,space=0},count=4,*data)
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702E20,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702E24,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702E28,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702E40,size=1,space=0},count=4,*data)
data: 00 00 00 80
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702E44,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702E48,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702E4C,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702E50,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702E54,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702E58,size=1,space=0},count=4,*data)
data: 00 01 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F00,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F04,size=1,space=0},count=4,*data)
data: 00 00 21 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F08,size=1,space=0},count=4,*data)
data: 00 00 00 0E
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F0C,size=1,space=0},count=4,*data)
data: 14 00 00 60
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F10,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F14,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F18,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F1C,size=1,space=0},count=4,*data)
data: 02 02 02 02
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F20,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F24,size=1,space=0},count=4,*data)
data: 02 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F28,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F2C,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F30,size=1,space=0},count=4,*data)
data: 00 00 00 15
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F34,size=1,space=0},count=4,*data)
data: 00 0C 00 20
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F38,size=1,space=0},count=4,*data)
data: 00 0E 0E 0E
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F3C,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F40,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F44,size=1,space=0},count=4,*data)
data: 0C 03 02 80
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F48,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F4C,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F50,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F54,size=1,space=0},count=4,*data)
data: 24 44 44 44
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F58,size=1,space=0},count=4,*data)
data: 44 44 44 44
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F5C,size=1,space=0},count=4,*data)
data: 44 44 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F60,size=1,space=0},count=4,*data)
data: 00 40 00 40
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F64,size=1,space=0},count=4,*data)
data: 00 40 00 40
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F68,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F6C,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F70,size=1,space=0},count=4,*data)
data: 00 40 00 40
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F74,size=1,space=0},count=4,*data)
data: 00 40 00 40
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F78,size=1,space=0},count=4,*data)
data: 00 40 00 40
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F7C,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F80,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F84,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F88,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F8C,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F90,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F94,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F98,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702F9C,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702FA0,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702FA4,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702FA8,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702FAC,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702FB0,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702FB4,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702FB8,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702FBC,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702FC0,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702FC4,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702FC8,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702FCC,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702FD0,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702FD4,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702FD8,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702FDC,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702FE0,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702FE4,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702FE8,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702FEC,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702FF0,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702FF4,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702FF8,size=1,space=0},count=4,*data)
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702FFC,size=1,space=0},count=4,*data)
data: 00 00 00 00
CCSAPI connection #1 from DESKTOP-CLV1MBM closed at Mon Feb 18 16:08:47 2019
CCSAPI connection #1 accepted from DESKTOP-CLV1MBM at Mon Feb 18 16:08:49 2019
check_min_version(serverh=0,*version)
api version: 00000004 00000006
available_connections(serverh=0,*count,*cc)
connections: {0,70,0xa9fefa33}
cc_version(serverh=0,cc_index=0,index=0,*version)
config_chain(serverh=0,cc=0,count=1,*devlist,*generic)
devlist: mpc9132
get_config_chain(serverh=0,cc=0)
*** unhandled(command=163) ***
config_server(config_reg=3,config_data=0x00000001)
reset_to_debug(serverh=0,cc=0)
stop_core(coreh.{serverh=0,cc_index=0,chain_pos=1})
read_reg(coreh.{serverh=0,cc_index=0,chain_pos=1},index=2032,count=1,*reg)
reg: FFFFFFFC
in(coreh.{serverh=0,cc_index=0,chain_pos=1},count=8,addr={0x00000000,0x00002711,0x00000000,0x00000000}
data: 49 34 05 35 FD D0 2B 90
read_reg(coreh.{serverh=0,cc_index=0,chain_pos=1},index=8,count=1,*reg)
reg: 00000000
core_run_mode(serverh=0,*mode)
reg: 00
#5 repeats
reg: 0F
reg: F7
write_memory(coreh.{serverh=0,cc_index=0,chain_pos=1},
addr.{addr_hi=0x00000000,addr_lo=0xFF700C08,size=4,space=0},count=4,*data)
data: 00080000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF700C10,size=4,space=0},count=4,*data)
data: 80F00013
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF700C28,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF700C30,size=4,space=0},count=4,*data)
data: 80F0001E
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702000,size=4,space=0},count=4,*data)
data: 0000007F
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702008,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702010,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702018,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702080,size=4,space=0},count=4,*data)
data: 80014402
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702084,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702088,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF70208C,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF7020C0,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF7020C4,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF7020C8,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF7020CC,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702100,size=4,space=0},count=4,*data)
data: 00070000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702104,size=4,space=0},count=4,*data)
data: 80330104
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702108,size=4,space=0},count=4,*data)
data: 5F5B0644
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF70210C,size=4,space=0},count=4,*data)
data: 0FA89190
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702110,size=4,space=0},count=4,*data)
data: 470C0008
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702114,size=4,space=0},count=4,*data)
data: 24401010
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702118,size=4,space=0},count=4,*data)
data: 00061420
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF70211C,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702120,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702124,size=4,space=0},count=4,*data)
data: 0C30030C
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702128,size=4,space=0},count=4,*data)
data: DEADBEEF
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702130,size=4,space=0},count=4,*data)
data: 02800000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702148,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF70214C,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702160,size=4,space=0},count=4,*data)
data: 00000001
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702164,size=4,space=0},count=4,*data)
data: 02401400
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702170,size=4,space=0},count=4,*data)
data: 89080600
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702174,size=4,space=0},count=4,*data)
data: 8655F600
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF70217C,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702180,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702184,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702190,size=4,space=0},count=4,*data)
data: 07070708
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702194,size=4,space=0},count=4,*data)
data: 08080900
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702200,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702204,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702208,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF70220C,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702210,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702214,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702B20,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702B24,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702B28,size=4,space=0},count=4,*data)
data: 80000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702B2C,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702BF8,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702BFC,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702D00,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702D20,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702D24,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702D28,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702D2C,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702D30,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702D34,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702D38,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702D3C,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702D40,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702D44,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702E00,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702E04,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702E08,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702E20,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702E24,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702E28,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702E40,size=4,space=0},count=4,*data)
data: 8000119D
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702E44,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702E48,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702E4C,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702E50,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702E54,size=4,space=0},count=4,*data)
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702E58,size=4,space=0},count=4,*data)
data: 00010000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: C70C0008
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 80
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 01 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 21 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 0E
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 14 00 00 60
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 02 02 02 02
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 02 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 15
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 0C 00 20
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 0E 0E 0E
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 0C 03 02 80
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 44 44 44
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 44 44 44 44
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 44 44 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 40 00 40
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 40 00 40
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 40 00 40
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 40 00 40
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 40 00 40
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
CCSAPI connection #1 from DESKTOP-CLV1MBM closed at Mon Feb 18 16:09:10 2019
CCSAPI connection #1 accepted from DESKTOP-CLV1MBM at Mon Feb 18 16:09:11 2019
devlist: mpc9132
reg: FFFFFFFC
reg: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00080000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 80F00013
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 80F0001E
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 0000007F
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 80014402
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00070000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 80330104
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 5F5B0644
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 0FA89190
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 470C0008
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24401010
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00061420
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 0C30030C
reg: 00
#5 repeats
reg: 0F
reg: F7
data: DEADBEEF
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 02800000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000001
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 02401400
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 89080600
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 8655F600
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 07070708
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 08080900
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 80000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 8000119D
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00010000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: C70C0008
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 80
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 01 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 21 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 0E
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 14 00 00 60
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 02 02 02 02
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 02 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 15
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 0C 00 20
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 0E 0E 0E
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 0C 03 02 80
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 44 44 44
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 44 44 44 44
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 44 44 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 40 00 40
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 40 00 40
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 40 00 40
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 40 00 40
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 40 00 40
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
CCSAPI connection #1 from DESKTOP-CLV1MBM closed at Mon Feb 18 16:09:26 2019
CCSAPI connection #1 accepted from DESKTOP-CLV1MBM at Mon Feb 18 16:09:27 2019
devlist: mpc9132
reg: FFFFFFFC
reg: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00080000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 80F00013
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 80F0001E
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 0000007F
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 80014402
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00070000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 80330104
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 5F5B0644
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 0FA89190
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 470C0008
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24401010
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00061420
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 0C30030C
reg: 00
#5 repeats
reg: 0F
reg: F7
data: DEADBEEF
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 02800000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000001
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 02401400
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 89080600
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 8655F600
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 07070708
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 08080900
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 80000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 8000119D
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00010000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: C70C0008
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
read_register(coreh.{serverh=0,cc_index=0,chain_pos=1},index=30000,count=1,size=8,*reg)
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 80
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 01 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 21 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 0E
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 14 00 00 60
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 02 02 02 02
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 02 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 15
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 0C 00 20
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 0E 0E 0E
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 0C 03 02 80
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 44 44 44
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 44 44 44 44
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 44 44 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 40 00 40
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 40 00 40
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 40 00 40
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 40 00 40
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 40 00 40
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
read_memory(coreh.{serverh=0,cc_index=0,chain_pos=1},
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00 00 00 00
CCSAPI connection #1 from DESKTOP-CLV1MBM closed at Mon Feb 18 16:09:41 2019
CCSAPI connection #1 accepted from DESKTOP-CLV1MBM at Mon Feb 18 16:09:43 2019
devlist: mpc9132
reg: FFFFFFFC
reg: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00080000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 80F00013
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 80F0001E
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 0000007F
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 80014402
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00070000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 80330104
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 5F5B0644
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 0FA89190
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 470C0008
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24401010
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00061420
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 0C30030C
reg: 00
#5 repeats
reg: 0F
reg: F7
data: DEADBEEF
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 03000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000001
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 02401400
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 89080600
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 8655F600
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 07070708
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 08080900
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 80000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 8000119D
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00000000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 00010000
reg: 00
#5 repeats
reg: 0F
reg: F7
data: C70C0008
reg: 00
#5 repeats
reg: 0F
reg: F7
addr.{addr_hi=0x00000000,addr_lo=0xFF702114,size=1,space=0},count=4,*data)
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
reg: 00
#5 repeats
reg: 0F
reg: F7
data: 24 40 10 10
CCSAPI connection #1 from DESKTOP-CLV1MBM closed at Mon Feb 18 16:10:12 2019
(bin) 2 %
Patils
