spi data transfer problem
1,115件の閲覧回数
harshadgami
hello sir ,
i have used TWR-K20D72 freescale board. in this board i connect CAT25256 (EPROM). i have write data in eeprom memory but faced a problem because of my initilization problem also problem of data write and read.
my system clock frequency is 72mhz. i have set  1 mhz baud rate for spi and how to set it.
#include "common.h"
/* ================== EEPROM command macros ==================*/
#define WR_EN 0x06
#define WR_DI 0x04
#define RD_SR 0x05
#define WR_SR 0x01
#define READ 0x03
#define WRITE 0x02
#define MAX_PAGE_SIZE 64
#define CS_ENABLE        GPIOD_PCOR |= (1 << 4)
#define CS_DISABLE GPIOD_PSOR |= (1 << 4)
#define CS_GPIO_CONFIG                PORTD_PCR4 = PORT_PCR_MUX(0x1)
#define CS_DIR_OUT GPIOD_PDDR |= (1 << 4)
#define PCS0                            0x1
#define DATA 'A'
#define ADDRESS        0x0000
/*=============== Functions declaration ====================*/
void spi_init(void);
char spi_send(char);
void delay(void);
void isDeviceReady(void);
void my_delay(void);
void eeprom_write(int address);
char eeprom_read(int address);
static char tmp;
///please write a correct spi_send byte function
char spi_send(char Txfifo)
    SPI0_MCR   &= ~SPI_MCR_HALT_MASK;      //Start Transfer
                   SPI0_PUSHR = Txfifo;
    SPI0_MCR   |= SPI_MCR_HALT_MASK;       //Stop Transfer
    while(!(SPI0_SR & SPI_SR_TCF_MASK));   //Wait for transfer complete flag
                   SPI0_MCR   |= SPI_MCR_CLR_TXF_MASK;
                   tmp=SPI0_POPR;
                   return tmp;
/////please write a correct spi_receive byte function
uint8_t spi_receive()
                    SPI0_MCR |= SPI_MCR_CLR_RXF_MASK;
                    SPI0_SR |= SPI_SR_TCF_MASK;
                    SPI0_PUSHR = 0x00;
                    //while (!(SPI0_SR & SPI_SR_TCF_MASK)) {}
                    return ((char)SPI0_POPR);
void spi_init(void)
  SIM_SCGC5 |= SIM_SCGC5_PORTD_MASK;      //Turn on clock to D module
  SIM_SCGC6 |= SIM_SCGC6_SPI0_MASK;       //Enable SPI0 clock
  CS_GPIO_CONFIG;                // Configured GPIO
  CS_DIR_OUT; // Select CS pin as Output direction
  CS_DISABLE; // Disable CS
  PORTD_PCR1 = PORT_PCR_MUX(0x2);    //Set PTC5 to mux 2 [SPI0_SCK]
  PORTD_PCR2 = PORT_PCR_MUX(0x2);    //Set PTC6 to mux 2 [SPI0_MOSI]
  PORTD_PCR3 = PORT_PCR_MUX(0x2);    //Set PTC7 to mux 2 [SPIO_MISO]
                SPI0_MCR |= (SPI_MCR_MSTR_MASK |   //DSPI is in Master mode.
  SPI_MCR_HALT_MASK); //Stop transfers
  SPI0_MCR &= ~SPI_MCR_PCSIS(1);
      // how to set 1 mhz???please write a correction
  SPI0_CTAR0 |= (SPI_CTAR_PBR(3) | SPI_CTAR_BR(0x04));
              //Frame Size = 8 bits
              SPI0_CTAR0  &= ~SPI_CTAR_FMSZ(7);
              SPI0_MCR    &= ~SPI_MCR_MDIS_MASK; //Enable module
/* ============ Send Write Enable Command =========== */
void write_enable(void)
  CS_ENABLE;
  my_delay();
  spi_send(WR_EN);                // Send Write Enable Command
                my_delay();
  CS_DISABLE;
/* ============ Send Write Disable Command =========== */
void write_disable(void)
  CS_ENABLE;
                my_delay();
  spi_send(WR_DI);                // Send Write Enable Command
                my_delay();
  CS_DISABLE;
  // Send Write Enable Comamnd
  write_enable();
  // Sequence of Write Command
  CS_ENABLE;
                my_delay();
  spi_send(WRITE); // Send writing command to EEPROM
  spi_send(address >> 8); // Send Writing address
  spi_send(address);        // Send LSB Address
                spi_send(DATA);
                my_delay();
  // Disable Chip Selection Pin
  CS_DISABLE;
  // Delay for processing Write byte into EEPROM location
  // Disable Write
  write_disable();
                my_delay();
  static char temp;
  // Enable Chip selection pin
  CS_ENABLE;
                my_delay();
  spi_send(READ);           // Send Read command
  spi_send(address >> 8); // Send address from where to read form EEPROM
  temp=spi_receive(0xff);
  CS_DISABLE;
  my_delay();
  CS_ENABLE;
                my_delay();
  // Disable Chip selection pin
  CS_DISABLE;
                return temp;
void my_delay(void)
  volatile uint32_t delayTicks = 2000;
  while(delayTicks--)
  __asm("NOP");
void delay(void)
  volatile uint32_t delayTicks = 2000000;
  while(delayTicks--)
  __asm("NOP");
void main()
              char data;
                spi_init();
  delay();
              // Write multiple bytes into EEPROM
  eeprom_write(ADDRESS);
  // Read multiples bytes from EEPROM
  data=eeprom_read(ADDRESS);
  while(1);
3 返答(返信)
537件の閲覧回数
harshadgami
sir, i am currently used IAR embedded workbatch software.
In this how i can set 1MHZ clock frequency.
how SPI0_PUSH & SPI0_POPR worked???
537件の閲覧回数
Hello Harshad,
Please refer to the calculation formula of  Reference manual
Alice
537件の閲覧回数
Hello harshad,
Are you sure the the core/system clock is 72M?
I recommend you create on PE project ,then add the component of SPI,
there is demo code about  SPI and the easy configuration :
About how to find these demos you can refer to this DOC:
How to Start CAN Module Development on KDS v3.2.0 + Processor Expert  (this is the same with CW)
Hope it helps
Alice
