external structur and L1823
940件の閲覧回数
ExternalStructu
I do not understand the problem
I declare in header file
typedef union{  byte bRS_Event;  struct  {    byte bStatus_1:1;    byte bStatus_2:1;        }u;}ST_FLAGS_RS_EVENT;extern ST_FLAGS_RS_EVENT stRS_Event;
L1823: External object stRS_Event in C:\Prog\GRx\Project1.2\Project_Data\Standard\ObjectCode\trames_rs.c.o created by default
Help me
Thank you
タグ(1)
385件の閲覧回数
CrasyCat
Specialist III
Hello
The code snippet you have provided below is showing the declaration for variable stRS_Event.
Did you place a definition fro the same variable in one of your application .c file?
Definition should look as follows and must reside in a source file (not an include file).:
CrasyCat
386件の閲覧回数
CrasyCat
Specialist III
Hello
CrasyCat
