compiler setting (callee not defined, compiler no error)
775件の閲覧回数
leslieyang0509
Codewarrior 10.3
When caller call a callee, the callee was not defined, the compiler result does not generate error.
How to change compiler setting to when callee was not defined, the compiler will generate error.
Example:
int main()
  foo();
the compiler will not generate error message.
Leslie
タグ(3)
538件の閲覧回数
CrasyCat
Specialist III
Hello
  Go to the ARM Compiler > Language page and check the Require Function Prototypes edit box.
CrasyCat
4 返答(返信)
538件の閲覧回数
CrasyCat
Specialist III
Hello
Which MCU are you targeting (HCS08, ColdFire, Kinetis, ...)?
CrasyCat
538件の閲覧回数
leslieyang0509
Dear Catherine,
NK60DN512
100MHz
mask 2N22D
Here is the snapshot of settings.
Leslie
539件の閲覧回数
CrasyCat
Specialist III
Hello
CrasyCat
538件の閲覧回数
leslieyang0509
Dear Catherine,
it works!
Thank you.
Leslie
