Where is the ROM_LIB keyword generated .S19 file?
899 次查看
bennyxu
LINK ROMLIB.lib AS ROM_LIB
generated .s19 file very small.
HOW to used to "ROM_LIB"
标记 (1)
334 次查看
CompilerGuru
Hi bennyxu,
AFAIK, there is nothing special about the SRecord generation with ROM libraries compared to the SRecord generation with "normally" linked applications.
Do you build from within the CW ide? If so, add a *.bbl file to your project, the SRecord ends up in the bin folder in the "normal" setup.
If you are building with a makefile, use the burner.exe to create an SRecord.
335 次查看
CompilerGuru
Hi bennyxu,
