Hello everybody,
I'm using Codewarrior 10.5, a P&E micro USB Multilink Interface and having a S08 microcontroller on my board.
So, basically I'm only searching for a way to read out the image, but I can't find menu for this kind of work.
Does anybody know how I can do this? I'm able to Flash and debug so the Connection should work fine.
Thanks and best regards,
Chris
已解决! 转到解答。
Hello Chris:
You can do this as explained in the next tutorial:
Dump my Device Memory | MCU on Eclipse
Regards!,
Jorge Gonzalez
Hello Chris:
Regards!,
Jorge Gonzalez
Greetings,
Within Codewarrior you will only be able to look at the data in flash and RAM while debugging the hardware. But if you want to read the flash and dump it into a file, then I would suggest getting the PROGHCS08 software from P&E and use the command "upload module" to dump the file as an S19 file.
Note, if the chip is secured and have not setup a backdoor key, then there is no way of reading the flash. You would need to unsecure the chip, which involves erasing all of flash and EEPROM.
Takao Yamada
P&E Microcomputer Systems
Hi Takao,
Thank you for this hint! When I need more advanced Features or I've to do it more often then I will use the PROGHCS08 tool.
I've an unsecure sample, so I've access to it.
Chris
