Linker external vector table not found
1,088件の閲覧回数
dominikbenz
Hi everybody
We are trying to convert our CodeWarrior 5.7 project to CodeWarrior 10.6 for our V2 coldfire software platform. In our Link command file (.lcf) we defined an external vector table with the following syntax:
.sec_vectors : {  HD_vectors.s (.text)  . = ALIGN (0x4); } > seg_vectortable
The Linker generates the following warning:
>File "HD_vectors.s" not found; assuming that "HD_vectors_s.obj" file was
How can we import the vector table from an external file?
thanks for your help!
タグ(4)
3 返答(返信)
843件の閲覧回数
trytohelp
Hi Dominik,
There are 2 questions here.
1- How to convert a classic project to Eclipse ?
CodeWarrior 5.7 is not the tool version but the version of the IDE which is a feature as the compiler or assembler.
CW for MCF v7.2 which is the last classic version included the IDE V5.9.
IDE V5.7 was included in CW for Coldfire V6.x version - on V6.3 and V6.4 for sure.
There are some documents you can refer to move your classic project to Eclipse.
      - AN4104, Converting ColdFire Projects to CodeWarrior Development Studio for Microcontrollers V10.0
            http://cache.freescale.com/files/soft_dev_tools/doc/app_note/AN4104.pd
    - 2 Technical Notes providing more information: TN256.pdf and TN268.pdf
There are 2 ways to convert a classic project to Eclipse:
    - manually using the documentation above,
    - imported system.
The importer is not working for complex project and has been removed after MCU V10.2.
From my experience to avoid problem I recommend to convert the project in different steps:
      - Step 1: convert project on last classic version: CW for MCF V7.2
          To be done depending of the version used you must refer to the TN256 and TN268.
          It's very important that the project is running under V7.2 before to move on Eclipse.
    - Step 2: convert on MCU V10.2 using the importer
          The MCU V10.2 can be downloaded on web site.
          This version includes a imported which convert the Classic project to Eclipse one - backup your project before ...
          Again we recommend you to check if the project is running.
    - Step 3: Move to MCU V10.6
          As your project is running on MCU V10.2 and can import it on MCU V10.6.
          This project should be running without problem.
In all case to avoid problem, for the manual solution too, I recommend to convert the project to the last classic version
CW for MCF V7.2 before to move on Eclipse.
The important conversions are done on V7.2 which are used on Eclipse too.
Having a running project on V7.2 it's a good step before to convert on Eclipse.
2- Regarding Vector table.
The project architecture used for Classic and Eclipse project is very similar.
In fact the same tools are used for both version.
The key difference is the IDE and the new features included under Eclipse.
But the compiler, assembler, linker are very similar to the classic version excepted newer versions.
The vector table is defined in a .c file included in the project (exceptions.c or Vectors.c for Processor Expert)
In the LCF file, the vector table is allocated in memory for instance:
.vectors :
exceptions_c.obj(.vectortable)
. = ALIGN (0x4);
    } >> code
or
  .interrupts :
    ___VECTOR_RAM = .;
    * (.vectortable)
    . = ALIGN (0x4);
  } > interrupts
What is the type of HD_vectors.s file ?
This is may be the problem.
I recommend you to refer to the MCU_ColdFire_Compiler.pdf manual for details.
There is a chapter named:
      Chapter 14 ELF Linker and Command Language
Pascal
Freescale Technical Support
843件の閲覧回数
dominikbenz
Thanks Pascal for your answer...
The project conversion is not the main problem. I created a new CW10.6 project with the existing sources. The programm is compilable and runnable, without problems.
I just get the described linker warning.
The HD_vectors.s file is a assembler file which contains the vector table in the following format:
.text
VECTOR_TABLE:
_VECTOR_TABLE:
INITSP:  .long ___SP_INIT          /* Initial SP   */
INITPC:  .long _asm_start          /* Initial PC   */
vector02: .long _asm_exception_handler /* Access Error   */
vector03: .long _asm_exception_handler /* Address Error  */
vector04: .long _asm_exception_handler /* Illegal Instruction */
vector05: .long _asm_exception_handler /* Reserved    */
vector06: .long _asm_exception_handler /* Reserved    */
vector07: .long _asm_exception_handler /* Reserved    */
vector08: .long _asm_exception_handler /* Privilege Violation */
vector09: .long _asm_exception_handler /* Trace    */
vectorFD: .long _irq_handler
vectorFE: .long _irq_handler
vectorFF: .long _irq_handler
.end
If I rename the importing file to
HD_vectors_s.obj (.text)
it runs without warning. Programm is executable...
Problem seems to be solved...
843件の閲覧回数
trytohelp
Hi Dominik,
It seems the linker is checking for .obj file by default.
Else a warning message is generated to inform user a possible wrong file name was detected.
I've never really played with the lcf file to check this behavior.
Pascal
