I have a CodeWarrior 10 application project that references multiple compiled libraries. One of these libraries references yet another library. All of the library projects build without any problems. However, when I try to build my application project, it gets numerous link errors for undefined symbols, all of which are located in that one sub-library. I thought that when building a library that references another library, that referenced library gets pulled into the library being built. Is that not the case with CodeWarrior 10? Is there a way to get CodeWarrior 10 to include referenced libraries in the final output when building a library project?
Solved! Go to Solution.
Hi CrasyCat. We're using ColdFire V1. However, I think that I've been able to resolve this particular issue. The sub-library was missing a source file, which had the function definitions in question, when it was built. It didn't complain when being built as a library because the function prototypes in the header file were declared as external.
Hello
Which MCU are you targeting (HCS08, Coldfire, Kinetis, ...)?
CrasyCat
