IDE for HCS08 Aw60 demo boards that runs on 64 bit Windows
720件の閲覧回数
b_r_clifford
I am trying to identify an IDE that runs on 64-bit windows that I can use to program the older freescale HCS08 AW60 demo boards using both assembly and C languages. Previously we have been using Codewarrior version 6 but this is not compatible with 64-bit windows. I have also tried Codewarrior version 11 but cannot see an option to create assembly files. Others have suggested there is a plugin to Eclipse that allows this but I have not been able to find this.
Any help on this would be appreciated.
2 返答(返信)
605件の閲覧回数
BlackNight
Hi Ben,
Not sure why you say this: you can add and use assembly files. By default the wizard offers C/C++ projects, but you can add as many assembly files as you want. Or you can create assembly only projects too with a few manual steps. It is the same as in previous CW for MCU versions.
I hope this helps,
Erich
605件の閲覧回数
Hello Ben Clifford,
Under  CodeWarrior V11, we also can create assembly files.
There is demo about assembly under CW:
CW MCU v11.1\MCU\CodeWarrior_Examples\HC_Examples\mc9s08aw60_demo
Hope it helps,
TIC
