HCS08 ICS configuration
684 次查看
Rob23
I am moving over from the ancient PEMicro HCS08 assembly development environment to CW and C. I can run the PEMicro debugger and S08SH8 at 20MHz bus speed but in CW I can't seem to configure the ICS to go above 16MHz. I have already used CW and C for slower bus applications but this project needs 20MHz.
Cheers
Rob
613 次查看
Julián_AragónM
Hi @Rob23,
Please look into AN2616, chapter 4.8 (Set Clock Frequency) which explains the formula to calculate bus frequency as well as an example code on how to configure the clock in C.
Julián
580 次查看
Rob23
Thanks for your reply. I did eventually manage to work it out. I feel a bit silly for enquiring so soon. LOL
I'll hang on to the AN for future. Thanks
Rob
PS, Do you know of a resource for converting PE Micro assembly to CW assembly?
563 次查看
Julián_AragónM
Hi @Rob23,
I apologize for the inconvenience, but we currently do not support tools or services for code converting.
Julián.
