Global Page on MC9S12XDP12
1,101件の閲覧回数
phil26
I work with codewarrior and a with a BDM p&E multilink sensor. I'm developping a bootloader for S12X and I have a problem to write at the adress 0xC000.
For me the logic adress 0xC000 is the same address that the global address 0x7FC000.
But If I display the logic adress 0xC000 and the global adress 0x7FC000 with the debugger Metrowerks I haven't the same value !!!
The driver flash works correctly because I write with out problem at the address 0x7F4000 and i see the same value at adress  0x4000.
Why it doesn't work for the address 0xC000 ?
Thank you for your help.
phil
タグ(1)
462件の閲覧回数
Alban
Senior Contributor II
Hi Phil,
A common mistake is to look at $C000 on the XGATE map, in this case this matches $FC000 global.
Maybe the window is set to look at XGATE map and was setup up as Logical (CPU) for $4000.
Cheers,
Alban
Message Edited by Alban on 2006-09-11 04:46 PM
463件の閲覧回数
Alban
Hi Phil,
Cheers,
Alban
