Compiler Settings/Preprocessor entries not correctly shown in IDE files
1,357 次查看
rhysdrummond
In my CodeWarrior projects (CW MCU 10.7, Windows) I define a few key items in Project Properties (specifically, C/C++ Build-Settings,Tool Settings/ARM GCC Assembler & C Compiler, Preprocessor).  I change the value of these #defines for different build configurations.
This actually works, and it produces the correct compile output. But what is shown in the IDE is not in sync with the build configuration I have selected. It seems to be stuck on one of the build configurations.
I've tried reloading, refreshing, rebuilding index, freshening all files, clean & rebuild, restarting CW, switching build configurations away and back, everything I can find- and the IDE content is still incorrect.
Can anyone please help me get the IDE settings in sync with the selected build configuration?
Thank you in advance.
1,282 次查看
rhysdrummond
SOLVED.
Window-Preferences, C/C++, Indexer. Select "Use active build configuration" in section "Build configuration for the indexer".
Thank you me :smileyhappy:
1,282 次查看
rhysdrummond
Extra information: It seems to always use the first Build Configuration that was made. Not the first in the list- I reordered it in .cproject, same result. I deleted the configuration it was using, and suddenly it started showing the correct thing. I remade the configuration I deleted- and made it active- and the IDE still shows the settings from the previous build configuration!
Looks like a legit bug to me. Can anyone confirm this, or suggest a workaround?
