Can someone please help me explain why sizeof( EVENT_LOG_t ) returns 8? It should be 6, right?
Does this have something to do with the way this structure is packed? How can I fix this?
My target MCU is Kinetis K10.
typedef struct { u32 time; u8 type; u8 code;}EVENT_LOG_t;
解決済! 解決策の投稿を見る。
Hello ignisuti,
You are right. This is caused by adding the padding bytes to keep data alignment.
If you need to get rid of these padding bytes you can add pragma:
#pragma pack(1)
but this might have an impact on speed performance.
Stanish
Hello ignisuti,
#pragma pack(1)
Stanish
