printf function in the TRK-KEA128_Lab1 gives error
1,002 次查看
ddpd
I am trying to debug the code of the example Lab1. I know its not the correct way.
Just wanted to ensure the correctness of the modified example program.
Basically I am trying to read and write from the UART line from my PC using a software C code.
I am getting this error
ARM_GCC_Support/ewl/EWL_C/src/sys/uart_console_io.c:200: undefined reference to `InitializeUART'
C:/Freescale/CW MCU v10.6/MCU/ARM_GCC_Support/ewl/lib/armv6-m\libuart.a(uart_console_io.o): In function `__read_console':
ARM_GCC_Support/ewl/EWL_C/src/sys/uart_console_io.c:93: undefined reference to `ReadUARTN'
C:/Freescale/CW MCU v10.6/MCU/ARM_GCC_Support/ewl/lib/armv6-m\libuart.a(uart_console_io.o): In function `__init_uart_console':
C:/Freescale/CW MCU v10.6/MCU/ARM_GCC_Support/ewl/lib/armv6-m\libuart.a(uart_console_io.o): In function `__write_console':
ARM_GCC_Support/ewl/EWL_C/src/sys/uart_console_io.c:151: undefined reference to `WriteUARTN'
mingw32-make: *** [TRK-KEA128_Lab1.elf] Error 1
I didn't get any satisfying answer from the previous blogs.
Please help me out in sorting this issue.
Thanks in advance
771 次查看
ZhangJennie
I just downloaded TRK-KEA128_LABTS1.zip from this url:
http://cache.freescale.com/files/microcontrollers/software/board_support_packages/TRK-KEA128_LABTS1....
I built it with CW10.6.4, there is no error.
if you want to use printf(), please pay attention to these points:
1. we need add
#include <stdio.h>
in your project.
2. if you want to print to console, choose ewl_hosted library model
3. "\n" is necessary to be added to the end of the string that we need printed out:
does this answer your question? If yes, please click the Correct Answer button. Thank you!
Zhang Jun
772 次查看
ZhangJennie
1. we need add
#include <stdio.h>
in your project.
Zhang Jun
771 次查看
ddpd
Thanks ZhangJennie.
Yes I wanted to print in the console. The output was displayed in the console after changing the settings to ewl_hosted.
771 次查看
ZhangJennie
you are welcome!
Zhang Jun
