hi
we are using mpc860tcvr66d4 for this we are using flash device S29alo16j55tfnr10 top boot sector (1M X 16) which is not there in the codewarrior 8.8 Ide so we added the device using FpdeviceConfig.xml and the device added which is showing in the Flash configuration. we are using my own Xml file, please go through it and see whether our base address is correct or not. we using Erase command which is showing succeeded. But when we are program the device it is showing flash base address error. Can you help in sorting the issue and help us finding base address. i'm attaching flash error ccs log and the Xml file which i'm using. Please help us.
my flash base address starts at BR0=0xFF800000
OR0=0xFF800050
which is configured in Configuration and Xml file.
Check your configuration using attached snapshots and Flash Programmer Configuration file.
These snapshots show CodeWarrior Flash Programmer setting for the MPC8323RDB board.
Compare your setting and Flash Programmer Configuration file.
Pavel Chubakov
It looks like that "Flash configuration" is incorrect.
Check the "Flash Memory Base Address".
Flash programmer tries to use address 0xFFC00000 and this address is not within flash boundaries.
Pavel Chubakov
We are confused how to find the base address for the FLASH ,we connected address lines AD30 to AD11 lines of the address bus . for that same we programmed the BR[0](0xFFE00801) and OR[0](0xFFE00080) . Now tell us what is the base address we need to for this flash address connections .
Check your "<membaseaddr>0xFFE00000</membaseaddr>" value and Flash address in your .cfg file.
See attached .xml file and .cfg file for the MPC866ADS board.
Pavel Chubakov
Thanks for reply @Pavel Chubakov,
my flash base address starts at BR0=0xFFE00801
OR0=0xFFE00080
16- bit configuration.(1Mx16X1)
my Sram base address starts at BR1=0x00000801
only code flash is the problem we are facing.
