Where can I find software to program the internal flash on a DSP56F805 via the parallel port on a PC
596件の閲覧回数
robfield
I am trying to program the internal flash on a DSP56F805. I designed the unit in about 2001 and have not looked at it for many years but I need to modify the program now. I can compile and load the program to an eval board but I need flash programming software to put in in the flash on my device.
503件の閲覧回数
TICS_Fiona
Thanks a lot for the feedback.
To program flash on DSP56F805, we can use:
1) Classic CodeWarrior v8.3
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=CW-56800E-DSC
It supports both USBTAP and parallel, it can only program with ELF file without project. It works on both Windows XP and Windows 7.  But it cannot program with S-record file.
2) flash_over_jtag
flash_over_jtag can only support parallel connection, it does not support USB interface.  And it program 56800 with S-record file. It does not support Windows 7 either.
I attached this tool.
Fiona Kuang
Technical Information & Commercial Support
