Variable is not getting assigned to 0.
1,011件の閲覧回数
venkateshgv
We are working on MC9S08QD4 with Code Warrior v6.3. When we assign 0 to a variable it is not getting assigned to 0 and it works with the previous value sometimes. Please share your feedback.
891件の閲覧回数
ZhangJennie
I wonder the problem is because of the optimization.
I suggest you cast the variable as "volatile" then try again. for example.
volatile int myval;
Jun Zhang
2 返答(返信)
891件の閲覧回数
BlackNight
Could you share a reproducible example?
for example, if you have something like:
int i;
i = 10;
i = 0;
i = 20;
then the compiler will be able to optimize this.
892件の閲覧回数
ZhangJennie
volatile int myval;
Jun Zhang
